You could put them behind the plate as well (white plastic spacers) will fit.II-Savy said:I would not use plastic washers. First they can crush and you can't paint them. I painted mine to hide them and they are hard to see unless you really try.
Whenever I get my GReddy TT & Profec, I'll be contacting you about your setup. I want mine to look exactly like yours. (thumb)03BlkMicaSPD said:fits, but its work. you have to do a little cutting. In my case I had to cut the Greddy Slots alot and make a custom trim to go around them so they would mount through insted of behind the plate. Then you have to trim your dash away some to get it to bolt in correctly.it![]()
