Yoko Parada......Hype? Also how much $$$
2 tires still have about 7/32 of tread left. It isn't much but since there is no current deal on buying 4, it will allow me to see how the 255's fit. If they don't flush up to the wheel well I will move them to the front and get 275's for the rear. I no it will not allow me to rotate tires, but I don't want 275's all the way around if that is the case.
I just ordered 2 255/50/20 for my CX9; Yoko Prada. I wanted a slightly wider tire so the tire isn't to much inside the wheel well. I hope the 255 will do the trick and not adjust my fuel consumption by much if any. I ordered thru a local Discount Tire and they do charge a TPMS rebuild kit per wheel. I think that is common, but somebody chime in if not. I believe it is about $15/wheel.
Rebuild? WTF is that? there's no taking it apart other than removing the pin to remove the air. RIPOFF!
