just press the old ones out and the new ones in... could prb do it with just a C clamp if you've got the patience. might have to cut up the clamp a bit...
If ur replacing the studs. Its pretty easy. U can leave the rotor on. Just take the wheel off. And give the stud a nice whack with a heavy hammer they'll come out from behind.
Either way is fine. I had a stripped nut on the driver rear. I bought a new one and whacked the old one out. It was pretty easy. Just spray some wd40 on it before hand.
Hmm, I'll go to the bank tomorrow, deposit some money, order some spacers, and check out the studs this weekend. You think my lugs will go on fine if I run the studs w/o spacers or will they be too long?
