boostedmsp
- 2003.5 Titanium Grey Metallic Mazdaspeed Protege
SOLD LOCALLY PLEASE CLOSE!
I am selling because I want to get my wife a reliable new car and I can get a sports car later on
. Thanks for looking!
I am not being forced to sell this I just don't really have time to give it all of the attention it needs.
This car drives fine and is my DD so mileage will go up.
Contact Info:
Bryan Stover
South Charleston WV
Quick Info:
2003.5 Mazda Mazdaspeed Protege - $6900 OBO
Item Description:
2003.5 Mazdaspeed Protege
TGM
76k miles
#935/2750
Here are the mods:
Optima Red Top
Thunder Tubular Manifold
GHL TBE
Defi Boost Gauge
Upgraded front motor mount
Alpine Ipod headunit
HKS Turbo Timer (needs installed correctly)
Altered customs FMIC kit
Monsterknob Piano black shift knob
ForceFed Steering wheel column gauge pod
Speedhut A pillar triple gauge pod
AEM Uego wideband
AEM Oil Pressure (needs oil filter sandwich)
AEM Oil Temperature (needs oil filter sandwich)
Synapse Synchronic BOV/adapter piped
JL w3 8"
Snotbox custom catch can
35% tint up front
20% on rear
TWM Performance short shifter
TWM Performance Black/Silver short shift boot
Kartboy Poly Shifter bushings
Kicker KS series front and rear speakers
Front rotors are cross drilled
new pads up front
New plugs and wires in last 3k miles
Not installed
DDM 5000k HID kit
Extras!
Comes with a low mileage turbo and wastegate (45kish miles)
low mileage primary 02 sensor
low mileage MAF
BRAND NEW Aem 5" dry filter
440cc WRX injectors
It currently has a couple of issues, the windshield is cracked along the bottom and will need to be replaced. The turbo to manifold bolts have came loose and need replaced. You cannot go into boost because of this but the car drives fine. Just has a massive boost leak. Also the primary o2 sensor needs replaced which will be included. The current turbo has some oil in the pipes so I am including an extra turbo so you can swap out. It has a couple of rips in the seat inserts but doesn't look bad. Also along the driver side door there are some rough spots where a previous owner probably locked their keys in the car and tried to get them out. It will probably need some new tires. Rear passenger side door actuator needs replaced.
Has a check engine light for no activity on primary o2 sensor and low and high input MAF so I am including replacements for both.
of course it has its share of dents and dings like any 7 year old car but nothing serious. PM if interested
Contact Info:
Bryan Stover
South Charleston WV
Quick Info:
Item Description:
TGM
76k miles
#935/2750
Here are the mods:
Optima Red Top
GHL TBE
Defi Boost Gauge
AEM Uego wideband
JL w3 8"
35% tint up front
20% on rear
new pads up front
Not installed
DDM 5000k HID kit
Extras!
low mileage MAF
440cc WRX injectors
