WTB : Magnaflow exhaust for speed6
Status
Not open for further replies.
Still in the market for a good used aftermarket exhaust for the speed6, let me know what you have. Also looking for diff mounts, short shift plate, counterweight, bushings, test pipe, boost gauge and vent pod
i have a cheap 2.5" custom vibrant exhaust i can sell for $150.. its half stock piping and new piping/muffler where our pipes get small it will give you pretty much the same results as the regular magnaflow.. for less money.. i also have an extra MS3 resonator you can weld in if you want really quiet low pro power..
for my MS6 ive had the CS, CPE, Magnaflow, Vibrant custom and currrently running a Magnaflow 3' custom.. the best flow is my current setup, best stealth power was the vibrant.. the others were nice flow but, too loud and the magnaflow they sell was ok.. but, almost all were overpriced for their quality and construction.. go get a local shop to make one or keeping looking for a used one to pop up..
If you don't mind me asking what did your current setup run? Do you know the model # of the muffler, I am assuming a single 3" right.
well its a 3" magnaflow short muffler and a long Magnfalow resonator and all the mandrel bent piping is sold prefab. the shop then cuts several pre fab bends and straight pieces to make a high flow low restriction pipe.. cost was $550.. from Road race engineering theyre a local evo tuner/builder specialist.. the guy who owns the shop is mike he can make you one but, hed need my car for a template.. mike is also an old school mazda tuner who owns this:
http://www.roadraceengineering.com/suitcasecar.htm
most muffler shops have a diffferent kind of bending tool and it leaves little ripples in the bend which create small amounts of turbulence.. my cheap muffler was made this way.. but, theyre cheaper and work just fine.. just not the best you can buy.. perfect for a budget tuner..
Status
