the motor has been built (forged) from the crank to the valves since 2002, i have been running turbo tuff rods forged pistions / with stock crank that was knife edged and cryo treated since then. I have also built the entire trans and shafts along with the ECU. Its 10 years later and my cranks is cracked - so i need to upgrade or replace - i already PM'd the K1 stroker kit seller to purchase that set up, also priced out a new crank at the dealer for 620 - but if a used un-damaged crank is around id rather utilize that.
So any other input?
