WOW!!! Turbo P5!
That is ill. Good old ohio boy. I need an e-mail or phone number for that kid. Dang.......................:eek: :D
And his "check engine" light is on. what a suprise. 500 miles and that turbo will be off the car.
A 300hp Protege5......in Idaho. I can guarantee that he's not getting those numbers. Definetly not at the wheels..... When all is said and done, the turbo does look nice. I would like some more info on it though.;)
you know, he could just have the ignition in the "on" position, with the engine not running....in which case the check engine light should be on.;)
check the tach. definitely idling. although i dont believe the 300hp remark at 10psi...thats just bs. not even possible at the crank w/ that amount of boost.
