Would these work?
Pattinjr2
2011 Mazda 2 Touring
Hey guys
im not much of a wheel expert so i was aondering i someone here could help me out. im looking to get new rims and a friend of mine has a set f rims and tires for a good price but before i waste the time and gas to drive there ide like to know if they will even fit on my car..
Heres the Specs he gave me- Nitto tires: 205/40zr17 84w
Konig rims: 4x100 bolt pattern
i know ive seen others with 17 inch rims on there 2, but the tires look very wide in the pics. (which i will try to post later) but does this sound like it would work? thanks!
Yeah, need to know offset. But I'd wager a guess (unless it's real aggressive) that it's around +35-40mm so you should be fine. On a 7" rim with +40 there's about a half inch of clearance to the strut so you're good there. Your new 205/40/17 is .5" bigger in diameter than the stock 185/55/15. So unless you're slammed to the ground on coilovers you'll be fine there also.
ok thanks :) ill ask about the offset and post when i figure it out. im gonna go over sunday to see how they look.. hopefully all goes well.
