Winter Setup Question
Element
Will a 17 x 7" wheel with a 40mm offset and 225 series rubber be an issue for the MS3? I am running RX8 wheels with 245/40/18s for summer and I had to roll my fenders. I wasn't sure if the 40mm offset would cause an issue.
Thanks!
So you rolled your rears? If so you might get away with that offset. On a stock car I would say no but if your rears are rolled you just might do it.
If you haven't already purchased your winter tires, I would recommend going with a 215 or 205 width. Narrow is better for winter.
