Winter Fuel Cuts
ohdavy1
Lately, I've been experiencing fuel cuts, I'm assuming because of the cold weather, when I try to go WOT or close to this. My current engine mods are SU SMIC, IC Pipes, J-pipe back Catless Exhaust, Stage Colder Plugs, SSAFC, and mbc set @ 9psi. Just wondering if there's something I need to be doing differently for winter. Download a new tune? Lower Boost? etc?
I think they have winter tunes for the SSAFC, but one of the vets should chime in soon. I know overboosting can cause fuel cut Is it possible you have a boost leak? I move my maf to the cold side, hair sprayed the couplers, and reset the ecu yesterday. Drove at night for 50 miles or so with no fuel cut yet.
No Boost Leaks. I'll have to check into the SSAFC sticky. Anyone suggest a good Map i should use for my settup?
