Will17" speed3 wheels with 55 offset work?
jdbrian
2014 Mazda CX-5 GS AWD
Would there be any negatives with using a set of 17x7 speed 3 wheels (2012) for winter tires? The offset is 55mm which will set the wheels in 5mm. I would be using the stock cx5 tire size for winter tires. It appears that the increase depth wouldn't be a problem as up to 8" wheels are spec'd by tire rack with up to a 50mm offset. Just wondering on negative impacts on handling due to the slightly narrower stance.
Thanks
The MS3 never came with 17" wheels... Yes they will work, considering you must be thinking of 17" MZ3 wheels with the same center bore size.
