A ARD208 Member : 2002 Mazda Protege ES Oct 18, 2009 #1 Will this engine header below fit in a regular non-hatchback protege. I think it was designed for a Protege 5.
J JC-MP5 Member : 1994 BG6S Oct 18, 2009 #2 The fronts of the Proteges are all the same. It doesn't matter what model it's for, so long as its a 2 litre engine. It should fit.
0 03zoomzoom Member : 2012 Mazda 3 i Touring Oct 18, 2009 #4 Just make sure the flange doesn't hit the oil pan. I picked up a header that we had to modify because of that problem. Another word to the wise, hook up the egr pipe before you get all the studs back on the manifold.
A ARD208 Member : 2002 Mazda Protege ES Oct 18, 2009 #5 Thank you all so much with the fast replies! Also thank you 03zoomzoom, I will keep that in mind.
0 03zoomzoom Member : 2012 Mazda 3 i Touring Oct 18, 2009 #6 Don't forget to get the sparkplug non-foulers for the downstream O2 sensor, or you'll throw a check engine light.
