Wideband vs.Narrowband Air/Fuel Gauge...
edricci
03.5 MazdaSpeed Protege
Okay so I am planning to get the ssafc sometime soon, but before that I need an air/fuel gauge. Wideband gauges are pretty expensive, but give digital readout of exact numbers. Narrowband gives you a range between lean, optimal, or rich... To be using this gauge to get a good tune with ssafc will I need wideband? Also where is best bang for the buck for gauges... Thanks!
Plus, only a wideband will let you datalog with the SSAFC.
Trying to use a narrowband for tuning is like sticking your hand out the window to figure out how fast you're going.
well wideband it is.... only problem is the widebands prices are high as a giants asshole!
not to mention most of those narrowbands are a hazard if you are epileptic, they are cool if you are high and listening to pink floyd though.
