R randyj69 Member : mp5 Jun 25, 2010 #1 would it be my valve seals cause i don't think it would be my rings cause its a lot of oil
J JReichle1 Member : 1999 Protege Sport 20 Jun 26, 2010 #2 Valve stem seals sounds like the problem. Check compression to see if the rings are gone. Good luck...
R randyj69 Member : mp5 Jun 26, 2010 #3 JReichle1 said: Valve stem seals sounds like the problem. Check compression to see if the rings are gone. Good luck... Click to expand... the compression is gooooooooooood its lik 150 on alll
