ion332 said:Its not identical, there are a few differences, but, they are rather small and the majority of the guts are the same..
Us v6 guys figured it out when we would buy a rebuild kit and the part number for the trans rebuild kit crossed over for the escort, 323, 626, protege, blah blah blah.
Then, we started looking at procuring parts from other cars.. One fairly popular mod was the MSP diff, then we started using ring gears etc..
The escape/tribute stuff is *mostly* compatible, but, iirc, some of the escape/tribute gear selectors are different. I think they have double syncros on a few gears..
ion332 said:One fairly popular mod was the MSP diff, ..
igdrasil said:What about the axles, did it fit with your stock axle or ordered msp axles?
ion332 said:Well, I am going to get them and see the differences.. I will compare helical angles, hardness, width, etc..
If they are different then I will go with them..
But, for my other trans I think I am going to go with the MPI gearset, that is if I can ever get ahold of Nick.![]()
CWiLL said:igdrasil- what tranny is in the 323 u post about? is it a fs tranny? what gears? and how many trannys do u think hes been through? i would love to buy the 3rd and 4th out of a gtx and cryo a whole tranny (or heat them w/e) but i dont want to spend the $ if its just gonna break. i want to find out alot of info before doing it.
i think we need a good write up
igdrasil said:Well, he doesnt talk much about his car... But he carries 3 extra transmissions when running a good event. But for what I see, mostly his problem comes with the axles. Hes a very good pilot also, he knows how to shift and not break them.
What I do know is that STOCK tranmission, was usually breaking (3rd gear) in dynos for anything over 480whp, and basically crossing the 1/4 mile in 5th gear.
Stock 1st and 2nd gear been holding well, means never broke, for up to 600whp.
Hes now using 88' USED gears in 3rd, 4th and 5th, so the gears came from a salvaged tranmission, bought in Australia. He doesnt uses 5th in a race anymore, the ratios changed good enough to cross the 1/4 mile in 4th gear with 605whp and yet not redlining.
By the way, his rev limiter is at 8200, so he uses 8k rpms, got a couple of videos running with 605whp @ 40psi
lcruz64 said:That's a monster.
What's he using for engine management? I now the videos are somewhere can you point me in the right direction? How come he's not a member?igdrasil said:This engine has a lot of potential, maybe some people here is disapointed with it, but if you see the problems, its mostly badly tuned engines.
His now shooting for 800whp, but a lot of work has arrived to him due to the fame ho got from this car. You would see it running 10 passes a day without issues, except for an axle, he changes it on the break and hes back.
1 big problem he found was the clutch, act xtreme plate and disk wasnt holding, so he had to order a custom one from ACT. Other problem was the 323 body, the front end of the body was twisting, so he had to reinforced it.
lcruz64 said:What's he using for engine management? I now the videos are somewhere can you point me in the right direction? How come he's not a member?
