which test pipe?
  • Thread starter Thread starter intak3_bLkMs3
  • Start date Start date
actually thinkin about dp and keeping the 2nd cat for emissions
Keeping the second cat is defeating the purpose. Your DP will be 3 inches and apparantly catless. You will then be necking it down to a pretty restrictive second cat in a smaller diameter pipe, and I'm not at all sure that it will keep your CEL's in check or pass emission testing.
You'd do better to either go catless with 3 inch piping all the way back to the cat back, or go with a catted DP, if you need emission control.
I don't know the basis of the earlier post suggesting that there are fitment issues with the TurboXS DP/RP. None of us on this thread with that set up have had any problems with fit. I'm not saying one manufacturer is better than another. I'm just saying don't make your choice on the assumption that there's a fitment issue with the TurboXS -- there is not.
