I bought a cheap ebay header as I didn't have the cash to dish out for a better one. The only thing bad I came across was the EGR bung on the header was crooked. All I did was cut the rear half of the weld between the bung and header, bent it back parallel and also aligned the bung parallel to the header flange. After that the EGR tube fit perfect. Grinding the weld with a grinder took off enough material to manipulate/maneuver it into place and re-weld it perfectly. Has been working well for me since I got her running about 1-2 months ago. That O2 sensor location on the collector is a tight fit though. the wire is barely touching the block but everything is running perfect.
ohkay cool thnaks for everyones opinions....that sounds like a pain in the ass. Id have to have one my of my buddies weld cause i have no idea how to. But i think im going to go with the M2 and if i come acrost that problem ill do that angel
