- 2003 mazda protege 5
i dont know if anyone already did this but i was wondering what gas you guys would prefer. ive been using sunono gas and it has done well for me.
I usually go to shell and valero, and price is the main deciding factor. Every station around here now has 10% ethanol which is bulls***, I hate that crap, makes my car run noticeably worse.
There have been several threads, and basically I go with this list:
http://www.toptiergas.com/retailers.html
The ethanol level is %10 here as well.
ethanol burns at a higher temperature than regular gasoline. our cars were designed prior to the introduction of high levels of ethanol. Therefore, our cars use inadequate spark plugs that are not designed to handle the increased ethanol level.
upgrade your spark plugs and it'll take care of the problems your having. I did and I noticed a 3 mpg increase, as well as better throttle response. I forget the name of the plugs, but if you look in my posts it shouldn't be too far down the list. the title probably has something to do with mpg or plugs.
Good read:
http://www.stopbuyingcrap.com/2006/11/20/brand-conscious-buying-3-gasoline/
I don't trust gas brands to keep my injectors clean. Use fuel treatment.
If you don't trust the gas makers to clean your injectors, how can you trust the other companies product's? They all claim the same thing.
LOL! In truth, you can't. However, I can't see gasoline companies putting much effort into adding a truly effective additive to fuel. It cuts into profits! There is no additive that is going to be completely effective in cleaning your fuel system, valves, or your flux capacitor - not even the ones you add yourself. I would still be more likely to trust a good manual additive before I trust the oil companies.
Also, the cheaper OTC fuel system cleaners have been found to be corrosive to components in your fuel line.
So you don't trust the gas companies' treatments and you don't trust OTC treatment, but you think we should use fuel treatment. Exactly what do you trust?
