Which CD-RW r u using?
serpentkilla1
05 Nissan Maxima SE
I am trying to burn mp3s to a cd-rw, but it will not play in the car. I'm using tdk, it says audio mp3 on the case but the s*** is not working. What r u guys using? or is the something i'n doing wrong? I'm also using nero 6.6 to burn.
your player has to be able to take cd-rw before you can play it. Most are only compatible with CD-R. Is the CD working on any other mp3 player? The program you use to burn an mp3 doesn't matter.
I'm using the alpine cda-7897, it reads cd-rw's according to the specs. It's playing on the the cpu and dvd player but when i put in the car it comes up with an error. It will play the cdr but i'm constantly changing songs so the cdr would be a waste.
I'll try the ones specifically for audio tomorrow, if that dose'nt work then i gues i'll have settle with the cd-r's
yes, you MUST finalize the disk.... and for that matter why bother using CD-RW's? CD-R's cost like a nickel each now, who cares if you make a few coasters.
serpentkilla1 said:
I've tried that to. You maybe it's the disk?
If you tried it in a DVD player and it reads it, it's probably not the disk. I'd keep trying the same disc on other players (friends, family) and try to confirm if the disc is okay.
umm, thsi may be stupid and pointless, but Are you trying to burn MP3's and play them on a player that reads cdrw's but doesn't play MP3's bychance? Use nero and create an audio disc but don't do mp3 do wav.
I'll try that
y would u want to burn them on cdrws newayz just buy a 100 spool of cheap ass cdr's for cheap and if they get scratched whtaever who cares
i have a jvc deck and a samsung burner, use nero mostly to burn i have no problems i usually get about 7-8 albums on one cd
buy good CD-R's!!! dont buy bad memorex CD-R's even though some are really nice.... they suck!!! buy good ones... one that i never have trouble with is Maxell.. they burn fast and they play like a normal cd would.... buy a s*** load of em so if u scratch em, u can just replace it.... hehe
they are all the same
no they are not.... each cd has the brands special thing they put on the piece of plastic... memorex sucks.. ive tried it it doesnt work... no matter how well i burned it.. it still doesnt play... yeah its worth buying only for data... not for making burn cd's....
