where to draw 12V power for "Rear Backing Camera?"
03 MSP OJ
i got red+ and black - DC12V lines and video output connecters from my Rear Backing camera
its gonna be mounted right on top of the rear vehicle plate, so i have to somehow find a + and - 12 connectors in the trunk area?
where should i be looking for?
black can go straight to earth/ground and red should go to the power side of the reverse light /bulb socket so that it only powers up when reverse is selected.
How much does the camera draw? Tapping the power into the reverse light could cause some blown fuses, if you do go that route make sure you use a relay so the draw is minimal.
Also how long does the camera take to power on before it shows the video? Might not be the best route if there is a delay.
just use the signal from the rear lights to trigger a relay that turns on the camera. Run a dedicated power wire (fused) from the battery for the camera relay. It takes 5 minutes to run the wire from the battery to the trunk.
