Where do I start?
ApolloP5
Mazda Protege5
After I purchase and install my new motor in my P5 (Fully forged) you can find the seller here https://www.speedcircuit.net/index....circuit-forged-fs-de-2-0l-protege-engine.html im planning on going with Wiesco pistons, Pauter rods, and the Mazdaspeed windage tray.
Im also doing ported heads stage 2. Any ideas on what i should do for power? I wanted to start with something small. Since it will be forged i was thinking maybe a Tune. Then forced induction later.
What are your thoughts?
Sent from my LG-K540 using Tapatalk
If you get the MSP upper oil pan/MBSP then you may as well put a turbo on it. You will have to get a piggyback or standalone to tune the car. You won't be able to make much more than 200hp naturally aspirated and you will need a ported or aftermarket intake manifold, cams, and a good header, along with a good tune. If you are spending $3500 on a built motor you may as well just throw a turbo on it now. A T28 on 8-10psi will make about 250whp.
The thing is it doesn't even have a motor in it right now
