I am installing a set of DRL / Turn Signals in a 2020 Touring (Australian Version), have got the turn signals working fine.
However have trouble finding a 12V positive feed to run the DRL. Only want the DRLs on when the engine is running. I have installed a relay that will turn off the DRL when the headlights are on, local law.
Has anyone found a power supply point in the engine bay that is only positive when the engine is running / or IStop is active?
* All sorted, thanks to @Rutedown.
www.mazdas247.com
Wiring for Daytime Lights and Turn Signal
I got the instructions below to add some DRL’s and turn signals. Can someone show me where to tap into the turn signal? Wire color and location.
