Where can I buy a vent kit?
Kosh
Bean-with-Bacon Megarocket
My exhaust has the white smoke. Dealer says I need a vent kit and it's $705. I just dropped over 6k on an engine rebuild I don't want to give them any more money. Where can I get a vent kit? I can't find anything online.
Very few will spend the big bucks for that upgrade. Switching to Shell Rotella T6 (full synthetic) 5w40 oil and raising idle rpm to 900, which requires an ECU reflash, usually solves the problem for less money. The Hypertech tuner is about half tge cost of the vent kit, allows you to reflash to higher idle rpm, remove a power limitation in first and second gear in the stock ECU map, and also increases power nicely.
There is a TSB for this issue
http://www.accessecu.com/accessport/mazda/AP-MAZ-002/TSB 01-002-11.pdf
If they won't cover it for some reason you can get the kit online...
http://www.jimellismazdaparts.com/products/VENTILATION-KIT/1957347/L3Y213S80B.html
