ouch....burned (flame2)silver03p5 said:bwahahaahahah pwn3d
I dunno how old it was, but it may have been a cable driven speedo. Ours are electronic and don't have gears IN the speedo. There's gotta be a sensor somewhere, I dunno if you can adjust it or not.D-rock240 said:Not sure about the P5, but my friend with an older camaro had to change some gears in the speedo to adjust it.
lol, touche`Protege52003 said:will keep the miles off you car's record. your car will hold it's value a little better!
aMaff said:I dunno how old it was, but it may have been a cable driven speedo. Ours are electronic and don't have gears IN the speedo. There's gotta be a sensor somewhere, I dunno if you can adjust it or not.
lol, touche`
Yeah its called a "SPEED SENSOR" and it HAS A Gear on it....Now whether or not they make any other gears that will fit it and correct your situation is another question...I would just get used to where you speedo willk read for the most common speeds...Its not hard to do...You'll get used to it.aMaff said:I dunno how old it was, but it may have been a cable driven speedo. Ours are electronic and don't have gears IN the speedo. There's gotta be a sensor somewhere, I dunno if you can adjust it or not.
lol, touche`
