Anyone installed wheel spacers on the msp stock racing hearts? I plan on getting some just wondering how it would look if anyone gots pictures post em up!
Sweet, flushness with racing harts. To bad they vibrate. So those are like bolt on spacers? To the original poster I ran 5mm with no problem. Any larger than that you should install larger studs or purchase adapter style ones
I have the 10mm Ichiba hub centric spacers and extended lugs. Makes the cars stance look so much better and no problems with vibrations either. Anything more than 5mm and you will need extended lugs or the bolt-on style.
This guy has 20mm in the front and 15mm in the back. click
