I'm about 90% sure my front D-side wheel bearing is getting bad, have vibes at high speed, the steering wheel shakes, and there is very slight wiggle up-down when grabbing the tire - but it's not the hub moving.
FSM calls for a SST to get the bearings out... basically looks like a press.
Is there any magic trick to doing this yourself, or is having a machine shop press/replace the bearings inevitable?
I know on some cars a perfectly placed peice of PVC pipe and BFH can do the trick.
And, I assume there's nothing special to removing the whole spindle to do this, right? Does it disconnect at the lower ball joint?
