we do have a forged crank and forged rods. forging is the process in which they are made, that doesn't necessarily make them big and able to take stuff. the rods are skinny, but they were created using a forged process, and thus are forged rods. not aftermarket strength forged, but forged none the less14LBS said:we have no forged internals. there small and scrony. also the car comes out of the box at around 5 1/2 to 6 1/2 psi. the key is in the pistons and rods. i've already experienced that and now I have a brand new motor and turbo. any questions feel free to ask.
huh? was i rude?14LBS said:they cant handle more boost and the type of forged i was refering to was the aftermarket forged that could handle more boost under pressure without breaking. i think you need to blow a motor and take it out and experience it first hand b4 you add you .02 also see the pieces for yourself and put them in.... thanks......
that was also only for a few dyno runs. if you do that every day, you'll break things. he was running a risk with that much boost and he was willing to take it, he just came out of it ok. if you run that risk every day, you won't come out so lucky every timejonnydoe48 said:joep went 18 psi on stock everything (except it was on race fuel)
jred321 said:that was also only for a few dyno runs. if you do that every day, you'll break things. he was running a risk with that much boost and he was willing to take it, he just came out of it ok. if you run that risk every day, you won't come out so lucky every time
nope, but it made it sound like it was ok to run that much as long as you had race gas. i was just clarifying.jonnydoe48 said:did i say he ran that everyday or something in my post?
since you knew what you were doing, what were your a/f ratios? your injector duty cycles? how far advanced was your timing? these things would help you to know why your motor broke, and you must have this information because you know what you're doing.14LBS said:yea you guys speak of goin happy with a boost nob but look at every1 on this forum claiming to be boostin 12 daily if not more. I know all about the tuning and fuel so b4 you think that your educating some1 about engine management you need to go and do your homework on the car. Lets see i believe that i started tweeking with the msp motor b4 you so dont trip.
Micah said:for the record - 9psi on a t3 - stock rod bolts gave out, the rest is history.
Don't be cheap, get forged internals - that was my mistake. Well that and not listening to everyone who told me to turn the boost down.
