perfworks said:i think they are very reliable
i just over aggresivly shift sometimes and killed the 3-4 shift fork ONCE!
they need to beef up the forks a little
pimpprotege69 said:You basically have to memorize the exact RPM speed each gear is at , at the proper speed. Takes a while but you can memorize like 20mph in 2nd and so on. Does not perfectly rev matching hurt your tranny?
bogeypro said:Just drive it like it was intended to be driven and you will be fine, want a sports car, buy the Mazdaspeed. The clutch isn't made to be dumped from 4000 rpm or slamed from 2 to third in a redlight race.
If you want to match it perfectly, take off and slowly increase speed as you GENTLY try to push the shifter to second without the clutch, when it slips in, you matched up, so the same for third and forth (harder to do). se if you can master shifting without using the clutch, you will be surprised to find out how much slower you should be going when you shift.
Protege Type 5 said:the car is very good for daily grind and a little spirited driving though
jjac28 said:i dont know why these guys are bashing the pro tranny.
i always drive my mazdas aggresively cos thats how they were designed to be driven and i havent had any problems with my 5sp whatsoever and this is my 2nd protege.
this is a fine car and thats why i keep on going back. if there was a serious tranny flaw dont you think that mazda would have a recall?
dont be stupid and race the car and you'll be fine. mazdaspeed was designed for that.
