axisboldaslove
- 07 MS3 GT Heavily Modified
"The Wall" I know you can increase pump pressure and all, but unless I've been under a rock for the last few months the highest pull I've seen on an MS3 is around 430 whp? And it can't push any farther because of restrictions in the stock DI fueling system... no aftermarket company (to my knowledge) has made bigger injectors or other components that can increase the fuel beyond what a high flow fuel pump and stock injectors/rail can provide. Meth helps, and a good amount too, but you can only go SO far with it. If this sounds wrong and I'm seriously misinformed, I apologize, hah. I haven't read up on new developments for the platform in a little while. I guess I should do some reading on MSF if that's the case.
yeah you need to go over to MSF cherryvodka is cageyvet over there, him and PTPerformance bet on his car to make 600 hp in 30days and he is going to go for it....djuosnteisn on his ms6 is 449 HP and 527 TQ stock block on a mustang dyno over there....i don't think fuel is a problem yet...i am sure that cherryvodka/cageyvet will find out
