I assume that you still have the stock four lug bolt pattern so you would want the wheel to come in the 4 x 100 bolt pattern to fit your hub. The rim you're looking at is 7.5 inches wide. Thats 1/2" wider than the stock rims on the MSP or MP3. That means you will need to know what the offset of the new wheels is to make sure you clear the struts on the inside and the fenders on the outside, and I didn't see it published on the vendor's site. You also don't mention whether you have changed your struts or springs; whether your car is at stock ride height or lowered. You would probably be safe with an offset between 45 and 50. As for tires, the stock size on the MSP is 215/45-17 which should work for you as well, but if clearance becomes an issue you could go to 205/40-17 though they will produce a harsher ride. You might take a look at the Tire Rack website... they have lots of useful info there as well as a large selection of tires and wheels.
