redwagon02
- '08 F150 FX2 screw - '06 G35 coupe - '06 GSXR600
The cheapest sh!t I can find. No money for gas anymore.
II-Savy said:Yes now I see the P5 reference. Sorry I ventured out to where the slow cars are. (crazy)
well you were the penis first. I simply thought I was giving my gas numbers in a thread. So I read it fast and posted without seeing the P5 label. Sue me.uclap5 said:(jerkit)
II-Savy said:well you were the penis first. I simply thought I was giving my gas numbers in a thread. So I read it fast and posted without seeing the P5 label. Sue me.
I'll see your ass and raise you a (butt)uclap5 said:(moon)
But fast car with gay driver is still equal SLOW... And MSP is not that faster anyway....II-Savy said:Yes now I see the P5 reference. Sorry I ventured out to where the slow cars are. (crazy)
"But fast car with gay driver is still equal SLOW" you wanna read that over again?slkt said:But fast car with gay driver is still equal SLOW... And MSP is not that faster anyway....
bump for that =)FLSilverP5 said:LOL what are you guys like 2? Trust me there are tons of P5's out there that can kick the crap outta ur MSP.
Poseur said:Anyone notice the diff in octane ratings in different elevations? I noticed awhile back when I drove to Colorado octane was much lower. Also interesting to note. but mid-grade is essentially just a mix of the 2 (ever notice how fuel trucks only have 2 diff tanks on them?) I can't remember the exacts, but it's a bit less higher octane than low, A friend's dad used to own a gas station, and I ran the numbers once. It's actually cheaper to buy A couple gallons of high grade on top of some low octane.
i use 93 to combat knock/detonation. sometimes its hard to find over 91 and believe it or not it makes a difference. if you cant find 93 or higher and the place has a higher elevation (like CO or some parts of AZ) you might as well turn down the boost to about 6ish, whereas im running 8 now. in CA i heard 93+ octane is almost non-existant.Poseur said:Don't our cars in particular run especially rich in the first place? makes it seem all but silly to me to push ANYHTING higher than the lowest octane. I've actually done some extended testing with this. Using Chevron 87 vs 92 trying to prove a point to a friend about fuel economy. 5 tanks of each, and i actually alternated some as well. Environmental and driving conditions were pretty set between everything and most involved driving up the pass to go boarding as that's when I put alot of miles on my car. I averaged 28.6mpg on 92 and 29.3 on 87. Not that this is the most scientific test, and my friend only had like .5mpg difference himself, but I'm prett convinced it makes a mileage difference. as far as anything else. Higher octane is prettymuch worthless unless you're heavily modded, and even at that alot of ppl overestimate what they've REALLY done, basically if you ever hear your car knock, up your octane..
As far as the whole issue of it being bad to switch, I don't KNOW for sure, but it seems to me that basically your ECU gets "used" to one sort of gas, so it essentially doesn't take full advantage of another one when switching unless you re-set your ecu by disconnecting your batt for 15min and pumping your brake pedal to release any residual juice....
