what mods do you have using Hypertech
74te27
Contributor
09 Mazdaspeed3 Gt
Let me start mine 09 Ms3 Gt.
Cp-e Tmic
Cp-e Hpfp
Cobb intake & tip
Cobb downpipe with stock catback
Sure Rmm
Denso ITV 22
stock bov
Mods in sig below. For clarity:
1. MSCAI
2. TurboXS 3 inch catless dp and rp into stock CBE (Vibrant UltraQuiet 3 inch straight through reso welded into middle of rp)
3. One step colder NGK plugs, gapped to .028"
4. HT tune
5. Sure RMM (not a power mod - only assists with shifting)
6. Stock everything else -stock bpv, stock TMIC, stock high pressure fuel pump, etc.
Pretty much full bolt, short of a custom turbo manifold. Using stock KO4:
AEM CAI
PG TIP
Corksport divorced wg DP
Corksport RP
28X7.5X2.5 FMIC
Stock BPV (went back on after Forge started leaking)
This setup does push the turbo pretty hard at maintained high loads, with high EGTs I've documented. Acceleration runs are no issue, just holding high load for a long time, like a high speed highway run. AFRs are totally safe and no other issues are present. The car is a pretty good rocket like this.
