What kind of cable is this near negative battery terminal? 2011 Mazda2
naboshi
Mazda 2
Hello,
I found a connector that has a brown-white cable broken, that connects into a socket on the negative battery terminal. Do you know what kind of cable is this, and how would I re-attach or otherwise fix it?
(Context: battery light would blink every now and then in a 2011 DE Mazda 2, seemed related to certain bumps in the road. Was suspecting something with the connections, so cleaned the battery terminals. Since that, the battery light comes on a few seconds after ignition, and stays on. I checked the battery voltage also the alternator, and they all seem fine, the car is otherwise running. So I suspect this was a loose cable that was now finally broken when I was cleaning the terminals? Not sure though).
Thank you!
