mazdadude
ZOOOOOOOOOM ZOOOOOOOOOM
- '16.5 Mazda CX-5 Touring
What was your 4 tires PSI when delivered to you>>>??? Better CHECK IT!!
The short story is, my tire pressures were not set correctly from dealer delivery. I recommend you check yours.(boom04)
The long story is...
I was disappointed with my cars handling, it felt too squirmy..
I wrote it off thinking that the tires are new, and that they need to release the oils a bit and break in...
At 600 miles I had given up on them, and was looking at replacing them with new tires...
Decide to check COLD pressures of the 4 tires... The closest to the recommended 36psi was still 4psi under inflated, both of the rear were 7 pounds under inflated at 29psi each...(smash)
LEFT FRONT = 30psi
RIGHT FRONT = 32psi
LEFT REAR = 29psi
RIGHT REAR = 29psi
All the pressures in all 4 tires were then brought to the factory sticker recommendation of 36 psi....(drive2)
I now get 4 more MPG on the same route I have been driving, and for the first time ever in MY LIFE got 41.1MPG in a car for a 140 mile trip.(first)
Did I mention that the car feels COMPLETELY DIFFERENT now and this fixed my one gripe I had with this car... I LOVE IT!!!
so please check your pressures... PLEASE NOTE: JUST BECAUSE YOUR TIRE LIGHT IS NOT LIT UP ON YOUR DASH, YOU DO NOT KNOW WHAT THE TIRE PRESSURES WERE AT WHEN THE LAST PERSON PRESSED THE TPMS RESET BUTTON. The only way to do this is to properly inflate all 4 tires to your desired pressure, and then press and hold the TPMS Reset button upon starting the car next time until the TPMS light goes out on the dash. After completing this step, your car now knows that all 4 tires are at your desired pressures and will alert you when there is a deviation from your last setting.
LEFT FRONT = 30psi
RIGHT FRONT = 32psi
LEFT REAR = 29psi
RIGHT REAR = 29psi
