fourthmeal
Banned
Laloosh I'm fairly certain you have this backwards here. Let me explain:
What you are saying (if I'm reading this correctly) is that under a partial throttle (lets say 47% open), the ECU is reading a pre-programmed map. And under WOT or close to it, it is going on the sensors. I think this is the exact inverse of what really goes on (and what you meant to say.)
Cars typically run a closed-loop map on low to mid-throttle ranges. Meaning, the ECU is reading all sensors, and running a map at the same time. It reads the map, and uses adaptive fuel trim strategy and timing learning to adjust its map + or - a trim value due to what it reads from the sensors. This is the nature of a closed-loop system, and its job is to achieve an ideal air/fuel ratio for proper emissions and MPG.
But when the throttle is mashed a bit more, say 75-80+% (a guess), the system should go into OPEN loop. At this point, the engine is reading no sensor, and uses its high throttle opening map combined with the effective information gathered during closed-loop operation, the Long Term Fuel Trim info picked up during Closed-Loop then is paired with the map that the ECU has already stored, and the car hauls ass at albiet at very rich (safe) ratio!
The information learned during the LTFT (long term fuel trim) strategy is then applied during WOT, open loop operation.
This is how it works.
you could still drive partial throttle, just watch how much boost it makes under how much gas you give it. Im not sure where this car goes closed/open loop but most cars are around 50 percent throttle. Say you are in 6th at 47 percent floored, your boost is set to 18 and you are hitting 18 at 47 percent throttle, You are still running off the pre programmed settings that are inbedded into the ecu. When you cross 50 percent, or wherever this car is set, it starts relying more on sensor to adjust everything.
Put it this way, its safer to be floored at 18psi then to be at partial throttle at 18psi. Just watch your guages, and drive normal. Or you can just floor your car in 6th at 3k rpm and hope it holds together.
