What is the correct CX-9 brake bleeding sequence? Please
mazda cx 9
Hi,
need help to clarify the brake bleeding sequence on a 2018 CX9 AWD, I have read because it has a diagonally split brake hydraulic system the correct sequence is rear passenger->front driver->rear driver->front passenger. Thanks for help.
Ya, I'd like to know what the correct sequence is as well. The furthest from the reservoir is kinda correct, but you have to measure the length of the brake lines as they go to the ABS unit and then snake around the body to the caliper. It might not be as simple as the furthest straight line distance from the reservoir.
