What is ideal exhaust?
NewfieArcher
2011 Mazda 2
Hey guys. I'm still new to tuning so I wanted to ask your opinions.
If I was to put a turbo on my 2 (where turbos cause minor increase in back pressure), what would the best performance exhaust be?
I also know CS has their full exhaust and combined with Andreas manifold I'd lose all cats. So would a larger custom exhaust like 2.5-3" improve power at all?
Lastly where do you get highflow cats? I'd like to put one into the exhaust so it's still legal.
Thanks for any information.
Andres manifold will not do you any good on a turbo set up as it would need to be replaced with a turbo manifold.
Generally with turbos, freer flowing is better so a larger exhaust would be better. I don't know for sure if 3" would be overkill but that's what I had on my Spec v and it made a difference over 2.5"
2.5-3in piping with a custom turbo mani... I have not been able to find a turbo manifold for the mazda2 the system will be fully custom as for cats the exhaust shop can help you out along with your custom piping
Magnaflow has high flow cats. I have had a couple on my Integra along with their stainless steel mufflers and resonators.
Might depend upon the turbo you end up with.
Isn't the stock exhaust closer to 2"? I'd think that fully 2.25" would be good for N/A. 2.5" sufficient for small turbo and 3" for large turbo.
A big turbo will probably be fairly useless on this small engine. It's important to properly size the turbo you use.
This is the great rule of thumb for turbo applications. A freer-flowing exhaust is almost never a bad thing, once the ECU is adjusted for it.
Others have mentioned that a large turbo for our little 1.5's will suck to drive. The engines may not be able to move enough exhaust gas to spool such a turbo until near-readline. A small/moderate turbo with mild/moderate boost and the correct tuning would provide a solid kick in the pants at more useful RPM's. A supercharger would actually be great, since you wouldn't have to change much plumbing upstream of the engine.
Any turbo company worth their salt will do this: if you are doing a custom or 1-off install, they will give you advice for exhaust requirements, and can help you figure out what turbo will work best with your application.
