justanothermp5
Banned
- Rust Bucket
I got Moog Escape endlinks...working very well so far
What you get from sam man? (tee hee it rhymed)
So I was wondering. After relocating my vacuum block to the brake booster, I then relocated my MAF to the cold pipe, installed my catch can and reset the fuel trims. I am still having a bucking issue with the car under boost, though it does not happen all the time. Would the fact that I left my BPV in and continued running the dual BOV/BPV setup cause any problems? I can't really see how it would since the MAF is now metering the air AFTER both valves do their thing. I do not have a solid tune with my AEM piggyback yet, so that is most likely the issue. Though I just want to make sure there aren't any other factors causing this, such as my leaky turbo that may or may not be on its death bed.
As long as it circulates to the same side of the maf then thats not the issue. I'd say not having a proper tune is your first problem. If the turbo is dying the... well...
Got some more work done on the BlackMSP:
$50 0_o how much was it per gallon?
