Beat on it a bit today. Went for a drive down 116 aka: The Devil's Triangle. Fun stuff. The road is pretty beat up, but the turns are crazy. Made a video, but it's like 3gigs, cause it's in 1080p, lol.
ZFR6F-11 Stock No. 4291 coppers are what I use.
Stock MSP spark plugs are platinum NGK PZFR6F's
Condensed list (brought to you by Tommy1005):
** Plugs with '1 step colder' listed should be used with boost applications of 10psi or above.
NGK BKR7E (copper)
NGK BKR7EIX-11 (iridium, 1 step colder)
NGK ZFR6FIX-11 (iridium, stock heat range)NGK ZFR7F-11 (1 step colder)NGK ZFR6F-11 (stock heat range)
Autolite AP3923 (platinum, 1 step colder)
Autolite APP3923 (double platinum, 1 step colder)
Autolite AR3923 (racing plugs, copper, 1 step colder)
Autolite AP, APP, and AR3924 (stock heat range)
Denso IK22 (1 step colder)
Denso IK20 (stock heat range)
Bosch 4230 (platinum, stock heat range)
Bosch 4310 (platinum +2, stock heat range)
Bosch 4418 (platinum +4, stock heat range)
Bosch 7562 (copper, stock heat range)
Well I finished painting my rims today, and gapped my new spark plugs that just came in. I'll be putting the rims on tomorrow, and I'll be installing the spark plugs real soon. Probably tomorrow if I get bored.
I received my knock sensor today from j&s and I'm going to be installing the j&s asap and cranking my boost back up :)
Which wheels did you paint? Got some pics?
I have 17in Rev model 4 wheels. They were a gunmetal with polished lip but now they are white. I don't have any pics yet
I hope you already have the stud to mount it, otherwise you're going to have to make one, or scour the earth high and low looking for one in the right size. It's a m10x1.25 to a m8x1.25, I believe.
I ran into the same thing. Ended up having to contact John, and bought the last two new studs in existence. He, and Steve from NSN, had to have these studs made specifically for mounting the knock sensor on a MSP.
Yea I sent my sensor to john at j&s and he drilled it out to 10mm so that I can just use a regular 10mm bolt now. Thanks for looking out tho.
Good deal. If it came down to it we were going to weld two stud together, lol. Didn't know you could just drill out the knock sensor, that would have made it much easier.
