I’m hoping for:
- a design as sharp looking as the CX-90,
- a width between the CX-60 & -90, and
- a foot or so longer than the -60.
- PHEV pricing $5k less than the -90,
- with a few more miles of all-electric range
- and light interior color choices like parchment or that nice brown on the CX-50.
That, finally a vehicle that I want.
- PHEV
- HUD
- Head Room
- Crossover
- Goldilocks size
Worries
- Mazda seats, re CX5
- Lousy safety tech, particularly LKAS. I have a mind numbing commute.
- Can I live with the knob? Mazda just won’t let full touch happen..
Correct, but I've seen a couple of reviews of the CX-60 that questioned its quality. We'll have to wait and see. Any ideas on when the CX-90 review embargo is lifted?Regarding your commute, are you looking for something with lane centering? Because it seems that starting with the CX-90, lane centering will be available.
I hated the need to use the command knob at first too but it has now become second nature. However you might be in luck....kindasorta. Our new CX-50 allows the use of the touchscreen when driving BUT only when using ACP/AA. While it doesn't give full functionality, it is better than none for those that wish to use it. I would imagine that this trend will continue on the CX-90 and CX-70.Worries
I agree with most of these item, however, I would like to see at least an 8" ground clearance. I dont go off-road, I just live in an area with to many potholes and Im not trying to bottom out.The 2 features that make the CX-70 worth waiting for are the inline 6 and rear wheel based all wheel drive. Otherwise, I likely would have a CX-50.
What I hope for a is a mid-sized, 2-row variant of the full-sized, 3-row CX-90. Think what the X5 is to the X7 or GV70 is to the GV80.
-Lower (none of these need 8.5" of ground clearance...none of these are going off-road.)
-Lighter
-Same width
-No longer than about 192"
What I expect...Nobody every got rich predicting what Mazda will do. If we call the CX-7 mid-sized, they have had a hole in their lineup since 2012 while introducing a subcompact (CX-30), a 2nd Compact (CX-50 to the CX-5) and a 2nd full-size (CX-90 added to CX-9) and neglecting the mid-size.
If you have pot holes big enough and deep enough to require 8" ground clearance to keep from bottoming out, you have way bigger problems than bottoming out. You are going to be blowing tires, bending rims, destroying suspension pieces. I grew up in Pittsburgh, PA and I know big potholes! We used to fill them with bricks and paint circles around them. The approach angles from both ends are not going to be the problem with a reasonably long wheelbase, so it is merely ground clearance and 6.5" is going to be plenty as long as you are not off roading. I have already investigated lowing kits for the X5, CX-50, RDX and other models on my radar screen.I agree with most of these item, however, I would like to see at least an 8" ground clearance. I dont go off-road, I just live in an area with to many potholes and Im not trying to bottom out.
