Weird Idle Problem
hinggu
Hi guys,
After finally fixing a massive vacuum leak from my intake manifold, I am still experiencing problems. The car runs and idles fine normally, but once the radiator fan kicks on, the car starts stumbling and sometimes the engine will die on me. The problem only happens when I am at idle. Car runs fine when I am driving and turbo boosts.
Is this a vacuum leak problem? Anyone have any ideas what it can be?
Thanks
Sounds like you still have a vac leak somewhere.
Check the ends of all the lines. I had a vacuum leak from where the end of one line had cracked. I couldn't see it immediately until I started disconnecting and reconnecting lines.
Thanks. I will double check all the lines again.
