Wastegate opening too early
Mazdaspeed Protege 2003.5
So, i have the forge WGA and the 5-10psi spring (green). And it'll hold boost until WOT, and just really low boost after. Weak spring, or upgrade spring? any ideas?
It's only 30$ for a whole set of different Thicknesses (5-10, 12-18 etc). Comes with 4. So i guess I will give that a try. If that doesn't work, I will guess its the turbo itself.
My Forge WGA is very erratic with the boost level lately, sometimes overboosting up to 13psi. It has the 5 psi Green spring. It has been a lot better since installing the SSAFC but I haven't had the EBC on to try to tune the boost.
It's been awhile since i been on sorry guys, but i got a MBC which seem to fix the issue. You guys know the best tuner for our cars thats best bang for your buck? or what are you guys going with? I really need a tune. I'm pushing 171k miles on 11lbs mid range 7 redline running strong. But i blew my lsd further mods is unlisted at the moment.
The ATP wastegate is where it's at! I've heard it's much more reliable in holding boost and lasts much longer than the Forge. For like $60 you might as well just replace it for a better product.
sounds like it is either defective or not installed properly. Id have someone else take a look at it or call forge and tell them you want an exchange first before you go buy something.
