- 2007 MS3
I`ve been trying to better understand our turbocharger and its control system. So far I`ve learned some interesting things and some that seem a little odd.
I need to make sure I understand the wastegate actuator correctly. Mostly, is it true that the actuator is actually holding the wastegate closed under normal conditions and when exhaust gas needs to be vented it allows the exhaust pressure to force the wastegate open? As opposed to the actuator opens the wastegate, which would otherwise be closed.
In other words, if you removed the actuator, the wastegate would be held open by the exhaust gasses and you would build no boost, as opposed to the gate just staying closed and the pressure never venting.
