t3ase said:snow? what the hell is snow?
Not if you live where there's salt on the road. If so, I'd be pulling over every couple minutes.t3ase said:you could just stop and wash your windshield at a gas station, if needed.
blynzoo said:Dex, there are actually many models of cars that spray off the wiper stalk. Take some time, and buy a spray nozzle from Home Depot or a hobby shop (for airbrush painting), and put that sucker on there. Works wonders.
peepsalot said:It would be insteresting to put the sprayers on the top of the glass, pointing down. Like if the lines could be concealed around the edge of the windshield, and routed up to the top edge, or maybe the corners. Actually it would probably look completely retarded, I don't know.
..because you can't buy a CF hood just because you like the look.kcbhiw said:Since you're going for the "weight reduction" setup by going carbon fiber, why not go the next step and remove the washer bottle and pump. Why not lose an extra 4 pounds to add to the 15 lost from the original hood. That'll make you even fastAr.
JAmazan said:i completely disagree, unless you remove the whole body of the car taking away the pump will not make you go faster... our cars w/ the exception of the speed protege...for us to get 1hp would have to remove 40 pounds, you do the math. second, unless u have money show cars take time to build......little by little....so with that being said...c/f is not rice.....plus it was cheaper than buying a hood from mazda to replace my other hood. any replys to my comment is welcome
Damn, this is getting pretty off topic, but I just felt like chiming in. Reducing weight ain't gonna give any HP, BUT it will affect acceleration since that is basically a function of the power to weight ratio.kcbhiw said:Since when does removing weight create horsepower? Do the math.![]()
peepsalot said:Damn, this is getting pretty off topic, but I just felt like chiming in. Reducing weight ain't gonna give any HP, BUT it will affect acceleration since that is basically a function of the power to weight ratio.
So, given a car with a particular weight and power, you can calculate how much weight would affect acceleration. Using that gain in acceleration, you could also calculate how much HP it would have taken to get there. Ok, my wording might not make much sense, so on to the equations.
P0 = initial power
P1 = effective "added power"
W0 = reduced weight
W1 = initial weight
P0/W0 = P1/W1
so. P1 = (P0/W0)*W1
So if I have a car with 150 WHP, weighing 2500 lbs, a 100 lb weight reduction would have the basically the same effect as if I had added 6.25 HP
150/2400*2500 = 156.25
Yeah, I know nobody asked me, but I was feeling nerdy, needed to do some simple equations...
