Well if ur using anti freeze instead of washer fluid that could be part of the problem. I'm hoping just a typo
Don't use just H20? That was my recent problem after running out of fluid this summer.... If it's clogged, take it off (unhook fluid line & a 10mm socket will help in removal iirc)and soak it in warm water, then try to force air through it to "clean" it out.
Hahahaha...maybe I should just keep this to myself but I always liked those lights if the rest of the car is glowing.
Anyways...so here's my update:
My nozzle had it's second coming! It worked fine today :-/
So no complaints there!
Is there better spray nozzles I can put on that actually spray and not just squirt?
If ur just using water it is possible that the water froze idk bout ur area buts its been rediculously cold here
