Warranty Question!
txmazdaspeed
'04 MZ3 S Hatch-Traded her 11/16/07 For '07 Tundra 5.7L
I was wondering if changing the headlight bulbs would void my warranty or any part of my warranty? Thanks for the info.
my best guess is that it wont. are you supposed to bnever replace your bulb? dont think so.
Yes and no.
If you change the bulb because it is bad then no.
If you change the bulbs and replace them with 110watt lamps that end up melting the wiring then yes they will not warranty the repair on the wiring. But the warranty on the rest of the car should remain in effect.
Yeah, just be sure to stay within the old lightbulb's output range to be safe. Otherwise, you'd be up the creek with two dead headlights and some burnt cables, along with possibly some other problems as well.
Thanks for the info guys. I have decided to go with Luminics pure blue bulbs for lows and highs and Luminics JDM yellow for the fogs.
