Z ZDA3 : 2015 Mazda3 Jan 4, 2025 #1 I'm just curious why a newly installed set of tires would be inflated 33 psi for the front and 32 psi for the rear. I always assumed all 4 tires should have the same amount of psi.
Mazdiod2 CX-5 Sport 2016.5 6MT Jan 4, 2025 #2 Yep, depending on the weight of the car.... unless the tires are a completely different size or something *(like on a tractor ) The tire pressure is listed on the door jamb for the size of tires the car was delivered with and approved by the DOT.
Z ZDA3 : 2015 Mazda3 Jan 5, 2025 #3 All 4 tires same size of course. I guess 1 psi difference between front and rear tires may not really be relevant?
sm1ke 2022 Mazda CX-9 Kuro Edition Moderator Contributor : Canada Jan 6, 2025 #4 ZDA3 said: All 4 tires same size of course. I guess 1 psi difference between front and rear tires may not really be relevant? Click to expand... It's not. Just air them up to the recommended PSI.
