Mine are a sticker. I could just get the edge up a tiny bit, but I could tell it was going to be very hard to get it all the way off, especially if it started ripping.They are actually printed onto the visor plastic.
Yeah, maybe a good idea. The plastic visor cover is so thin though that I'm not sure I could heat it enough to do much good. I have done a lot of debadging of vehicle bodies, so I do agree that heat is your friend in cases like this. Thanks.You're lucky it's stickers. Use a heatgun/blow dryer. It'll loosen up the glue and let you peel easily, just don't heat it up too long, especially if use a heatgun.
