Vibration/shaking at highway speeds
^ Everything seems fairly priced, other than the oil change. $60... better come with a damn blowjob for that much.
oil change was expensive. so was the tire patch. balancing the 4 summers generally means all 4, so the 30$ for the nail should have been less because it was already going to be balanced. mounting the tires for 18$ is a good deal tho.
Altough "mounting" them meant screwing them on...since they were already mounted on the rims...
I'm also having a similar issure I havnt been able to figure out. After the car sits for awhile itl shake as if I have a flat tire but it goes away in a mile or so and doesn't come back I thought it was a bent rim at first but it goes away the speed of it doesn't matter I also have the clunk with the steering wheel
