veritas80
23' CX5 Turbo
- SI, NY
I don't think this has been successful as an actual fixDid you see the post above about the insulation modification?
But sometimes it doesn't. It stops for a moment, then resumes at idle. At least on my car it does.the turbo noise is normal when car is under load and accelerating. Sounds like slight buzzing which disappers when yoy get your foot off the gas pedal.
I've had this a lot lately in the cold weather. It modulates with throttle, often disappearing momentarily when you take your foot off the gas, but then coming back. I'm sure everything is working normally, but it would be nice to quiet that sound.Hello i purchased a Cx5 Signature late last month and i have had the same issue mentioned here with the Buzzing sound when idled/ speeding up that is worse in the cold. I just took it to Mazda and they are saying the engine needs to "break in". They said the sound is the from the fuel injectors. I wanted to know if anyone has made any progress to an actual solution for this. thanks in advance
